Contributor I
AOS8 Controller Provision AP
Hi, just new to Aruba and need some help.
I've upgrade the controller to AOS 8.4, how do i provision new AP connected to the controller ?
Many thanks
Re: AOS8 Controller Provision AP
Configuration> Access Points.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Here you will find a Video Series on how to configure stuff on AOS 8.x Controllers:
https://www.youtube.com/playlist?list=PLsYGHuNuBZcatGA1POy6iVpVlDTLYzNFE
Contributor I
The AP appear on the Configuration - Access Points - Whitelist (Campus AP Whitelist) and i've change the status as Approve and Accepted; how do i enable the AP ?
The access point appears in the default Ap group.  By default the default ap-group does not have a WLAN.  You can use WLAN configuration to put a default WLAN in the default ap group, or create a new ap group, and then put a WLAN in that, and then move the ap to that new ap-group to broadcast your WLAN.
Contributor I
find the reason, license needs to be input :PScreen Shot 2019-03-06 at 13.21.56.png
