Re: AP-225 in Powersave mode performance
Cartman,
How do you know they are not at full power?  Does the Huawei switch say how much power they are drawing?  Does the access point say they are not at full power?
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
ArubaOS Consolidated Release Notes
Aruba Technical Webinars
Occasional Contributor I
1, From AP front LED, the power light is amber.
2, From AP power status, it shows poe-AF... about operational state
3, From Switch monitor page, it shows only 9w power is used.
Cartman,
Did you open a TAC case so ensure that your configuration is correct and there is not some incompatibility between the AP225 and the Huawei switch?
I'm not sure if i have efficient authorization to open a case. also I'm thinking about the compatible issue.
Till now no good solution.
Cartman,
Did you try enabling LLDP on any of the ports?  http://support.huawei.com/enterprise/docinforeader.action?contentId=DOC1000019448&partNo=100112
I have enable the LLDP on my switch S5700-24TP-PWR-SI, but the strange thing is the LLDP Negotiated POE power is only 0.2w, this is I find from AC about AP power status.
What version of ArubaOS are you running?
Hi ,  it is 6.4.1.0
Is there any way you can upgrade at some point? Here is a poe big fixed in 6.4.1.1
Hi, So the update include the fix to my problem? i will try with that.
