Re: AP-225 in Powersave mode performance
It *might* help.  It could not hurt.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
ArubaOS Consolidated Release Notes
Aruba Technical Webinars
Occasional Contributor I
Ok, I will try within these days. Thank you!
Did you find a resolution to this?  I'm having the same problem, though my Cisco switch does not have LLDP configured.
I had similar issue using Avaya 4850 switches.
issue ended up being the LLDP command limiting power to individual ports.
this is the command from Avaya CLI that limited ports to 802.3af
no lldp tx-tlv port 1/ALL,2/ALL dot3 mdi-power-support
Once command was disabled, AP's started functioning at full power. Power LED changed to green. AP did not need to be rebooted.
