AP-314 provisioning with AP-ANT-20W
I have some questions on provisioning for ap-314 with four AP-ANT-20W .
cannot find solution on datasheet or from the Internet.
mobility controler 6.5.4.10
I try the AP wizard , but no ANT-20W in the list of antenna.
so in the provision page for an AP314 :
ap installation mode : indoor
external antenna Gain, 5GHz : 0.0 ?  2.4GHz : 0.0 ?
external antenna Polarization  5GHz and 2.4GHZ :
0-CO-Polarized or 1-Cross-Polarized  ?
if someone can tell me what values and choice made for this antenna model , it will be great :)
for record , from the matrix-antenna :
Type   Dual-band omni, direct mount
BAND(S) 2.400 GHz - 2.500 GHz     4.900 GHz - 5.875 GHz
PEAK GAIN          2.0 dBi                        2.0 dBi
POLARIZATION & ELEMENT TYPE  Linear, vertical. Omnidirectional patterns at all frequencies
BEAMWIDTH (DEGREES)  360 (H-plane) 80 (E-plane)
VSWR < 2.0 :  1
MAX INPUT POWER     2 watts
regards,
Aruba
Re: AP-314 provisioning with AP-ANT-20W
Gain for provisioning can be copied from the matrix or antenna datasheet.
Assuming will be co-polarized when deployed correctly (all parallel).
/Onno
Thanks a lot for the answers.
What if the antenna are moved from parallel to all directions  ?
explanations :
we install parallel but in a warehouse and sometime (even at +12meter from the ground ) a good pallet can touch the antennas and set them in all directions.
Regards
Aruba
Then your coverage areas get messed up, and you will see reduced MIMO performance and throughput.
/Onno
ok .
thanks a lot for quick and clear answers.
