You probably should ask Oberon for an exact number. In the datasheet, they mention: "cover which is virtually transparent to wireless signals.", so I would not be too worried about that.
I would imagine that if you were to design an AP enclosure, that providing as low attenuation as possible would be one of the more important design criteria.
