Correct, this is mentioned in the
AP-370 Ordering Guide:
5 GHz radio has 4 connectors so 2 sets of JW026A or JW027A are necessary for full configurationYou should not leave antenna ports unconnected. In case you have to, you will need to put N-type 'terminators' (not available from Aruba) on the ports that are not in use to avoid damage to the radios in the AP, and expect reduced performance.
Original Message:
Sent: Dec 08, 2020 04:47 PM
Subject: AP-374 Antennas/Cisco 1550 Replacement?
Good Afternoon Jerrod,
I have a similar question in does the AP-374 model require antenna connections in all the Ports? (5G0/1/2/3, 2G0/1). Looking at the spec sheet, it indicates for full configuration for 5 GHZ will require 2 sets of JW027A.
LaMarcus Stanley
Original Message:
Sent: Sep 29, 2020 10:50 AM
For 2G0/2G1, I would connect the V-pol to 2G0 and H-pol to 2G1 on the antenna. For the 5G0/1/2/3 I would do the V-pol on 5G0, H-pol on 5G1, and the +45/-45 on the 5G2/3. It technically should not matter, but I *personally* just like to do it this way for consistency.
