Highlighted
Occasional Contributor I
Re: AP-375 won't join Wireless Manager
Thanks for the quick reply.
just for my understanding, this is what I see on one of the cluster controllers with command
#show ap deploy-profile
Profile enabled: no
Apply to default ap group: no
Blacklist enabled: no
AP deploy policy IP range Table
Starting IP  Ending IP
AP deploy policy IPv6 range Table
As it looks to me, deploy-profile is turned off. So an AP will not be redirected to controller-less mode. Am I correct on this?
Thanks again.
Highlighted
Frequent Contributor I
Is there anyone who got the AP-375 working out of the box connecting it to a 8.4 version controller/cluster?
Highlighted
MVP Expert
Yes, I have, multiple times. It shouldn't be any different than any other AP (depending on how you do controller discovery and if there is an Aruba Instant AP on the same L2 as the 375)
Jerrod Howard
Distinguished Technologist, TME
Highlighted
I agree that it shouldn't be different than any other AP.
Currently working with support for about two weeks because the AP-365's wont join the controller in MM and cluster of two controllers. All other AP-305's, currently about 500 of them and no problem at all.
What is your setup?
  • Are you working with CPsec?
  • Controllers in cluster or stand-alone?
  • AP's in same VLAN/IP-subnet?
  • Running 8.4.0.1?
Thanks in advance
