Highlighted
Frequent Contributor I
Re: AP-387 Bridge Setup
got the ap working in standalone mode after connecting it to a console cable. ill now follow the bridge guide that linked above. thanks for the help.
Highlighted
Update... after having Aruba support help, i have 6 IAP 305's and 2 AP-387s in a cluster. The 6 IAP 305's and 1 of the AP-387's are in portal mode. We have disabled extended SSID and created the mesh-link. As soon as i place one of the AP-387s to eth0 bridge enable to become the Point AP and reboot it, it disconnects no longer shows up in the cluster. Aruba tech support cannot figure out why this is happening. If i connect a console cable to the AP, its able to ping the portal AP-387 but none of the portal IAP-305's. All of the devices are on 8.6.0.2.
Highlighted
disregard the last post. I figured out i needed to reboot the entire cluster and it all works now.
