It´s already 8.7.1
So, what did I do:
configure
ipm
enable
ipm-power-reduction-step-prio ipm-step disable_alt_eth priority 5
ipm-power-reduction-step-prio ipm-step disable_usb priority 6
ipm-power-reduction-step-prio ipm-step cpu_throttle_25 priority 7
ipm-power-reduction-step-prio ipm-step cpu_throttle_50 priority 8
ipm-power-reduction-step-prio ipm-step cpu_throttle_75 priority 9
ipm-power-reduction-step-prio ipm-step radio_2ghz_power_3dB priority 10
ipm-power-reduction-step-prio ipm-step radio_5ghz_power_3dB priority 11
end
commit apply
wri mem
After Reboot:
Power Status
Item Value
Power Supply : POE-AT
LLDP Power : Successfully negotiated at 25.5W
Current Operational State : No restrictions (Overridden by LLDP)
Eth0 HW POE status : POE AT, LLDP power: 25.5W
Eth1 HW POE status : NONE, LLDP power: 0.0W
POE Mode : Shared
show ap-env
Antenna Type:Internal
Need USB field:Yes
radio0_channel:36E
radio1_channel:13
radio0_power_10x:18.0
radio1_power_10x:20.0
iap_master:1
installation_type:indoor
uap_controller_less:1
radio2_channel:100E
radio2_power_10x:18.0
split_5ghz_mode:enabled
=> Radio 2 is actually offline. Also GUI doesn´t show anything.
Update 1:
When I now want to set frequencies and change dBm settings, hit save, it tells me:
"This command can only be used when Dual 5G or Split 5G enabled This command can only be used when Dual 5G or Split 5G enabled This setting is only supported when split-5ghz-mode enabled"
=> show ap debug system-status
Fast Recovery report
Interface mode events start end PC
wifi0 legacy 0 N/A N/A N/A
wifi1 legacy 0 N/A N/A N/A
wifi2 legacy 0 N/A N/A N/A
Interface counters
Interface Rx_pkts Rx_errors Rx drops Tx_pkts Tx_errors Tx_drops Resets
wifi0 2216 4 5 2527 0 0 0
wifi1 79 0 30 935 0 0 0
wifi2 0 0 0 0 0 0 0
Modules
cdc_eem 2790 0 - Live 0xffffff8000860000
usbnet 26610 1 cdc_eem, Live 0xffffff8000985000
wifi_3_0 583205 0 - Live 0xffffff80024f1000
wifi_2_0 679450 0 - Live 0xffffff800244a000
qca_ol 1227896 2 wifi_3_0,wifi_2_0, Live 0xffffff800231d000
diagchar 188713 0 - Live 0xffffff80007fa000
crc_ccitt 1767 1 diagchar, Live 0xffffff80007f6000
qca_spectral 58205 1 qca_ol, Live 0xffffff80007e2000
ath_pktlog 18797 0 - Live 0xffffff80007da000 (P)
umac 3293904 5 wifi_3_0,wifi_2_0,qca_ol,qca_spectral,ath_pktlog, Live 0xffffff8001d36000
mem_manager 14770 3 wifi_2_0,qca_ol,umac, Live 0xffffff8001d2f000 (P)
asf 6890 3 qca_ol,ath_pktlog,umac, Live 0xffffff8001d2a000 (P)
qdf 110978 7 wifi_3_0,wifi_2_0,qca_ol,qca_spectral,ath_pktlog,umac,asf, Live 0xffffff8001d03000
bom 41109 0 - Live 0xffffff8001cf4000 (P)
anul 1876441 6 qca_ol,qca_spectral,umac, Live 0xffffff8001b1a000 (P)
asap_mod 17171719 7 qca_ol,umac,bom,anul, Live 0xffffff8000a98000 (P)
drvlog_mod 16693 4 qca_ol,umac,anul,asap_mod, Live 0xffffff8000a90000 (P)
uol 151809 3 umac,anul,asap_mod, Live 0xffffff8000a64000 (P)
bonding 124428 0 - Live 0xffffff80009c6000
ipm 19289 0 - Live 0xffffff80009bd000
isl28022 6941 0 - Live 0xffffff80009b8000
qca_nss_ipsecmgr 42140 1 uol, Live 0xffffff80009a9000
qca_nss_cfi_cryptoapi 42616 1 qca_nss_ipsecmgr, Live 0xffffff800099a000
qca_nss_crypto 36057 1 qca_nss_cfi_cryptoapi, Live 0xffffff800098d000
qca_nss_drv 1144522 9 wifi_3_0,wifi_2_0,qca_ol,umac,bom,anul,uol,qca_nss_ipsecmgr,qca_nss_crypto, Live 0xffffff8000863000
qca_nss_dp 48764 3 asap_mod,uol,qca_nss_drv, Live 0xffffff8000853000
qca_ssdk 1871330 2 qca_nss_ipsecmgr,qca_nss_dp, Live 0xffffff8000610000
Ethernet bonding
BondMode NumSlaves LinkPollIntvl(ms)
active-backup 1 400
Slave bonding info
SlaveId Name Link State #LinkFails
0 eth0 UP ACTIVE 0
Ethernet Duplex/Speed Settings
Autoneg Speed (Mbps) Duplex Iface
on 1000 Full eth0
on 5000 Full eth1
Master discovered by:(none found)
Boot Version
2.5.3.10 (74666)
Power Status
Item Value
POE Mode : Shared
Power Monitoring Information
Current(mW) Average(mW) Minimum(mW) Maximum(mW)
10321 9978 9665 11066
Note : Avg, Min and Max power are calculated using values sampled over the previous 60 seconds
Update 2
I enabled ap-poe-power-optimization enable
commit apply
=> No change
Update 3
Within the GUI => Configuration => Access Points I selected the access points and edited it, went to "Radio" and set "Split 5GHz mode" to "Default" while the manual settings for all 3 radios were still active. (It was set to "Enabled" before.)
Now the 2nd 5 GHz radio (Radio 2) is active!
Update 4
After rebooting the access point radio 2 is offline again.
Update 5
Again:
commit apply
wri mem
=> No change
Update 6
Within the GUI => Configuration => Access Points I selected the access points and edited it, went to "Radio" and changed TX power from 18.0 to 17.0 dBm. No error message about e.g. split 5 GHz mode.
Now the 2nd 5 GHz radio (Radio 2) is immediately active again!
Update 7
After rebooting the access point radio 2 is offline again.So what am I missing?
