Contributor I
AP Failover
Hi All,
How can I find what triggered the following AP failover? All of my APs failed from one controller to the other, but I find why.
(MC-02) #show ap debug system-status ap-name AP-01
HA Failover Information ----------------------- Date Time Reason (Latest 10) -------------------------------------- 2019-02-13 13:45:47 Failover request from standby: fail-over to 10.1.1.2
MVP Guru
Re: AP Failover
What kind of Aruba environment is this? Master-Local, VRRP, Clustered etc? In the first instance check the logs to see if a controller rebooted and the APs lost connectivity. If all APs failed over at the same time then its possible there was  network interruption at some point.
show log all | Include [AP NAME or IP]
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Contributor I
Re: AP Failover
This is a master-local environment, 6.5.x with a redundancy group configured. The logs don't show anything during this time related to APs failing over, only power adjustments.
