Occasional Contributor I
AP Low Power Report
Hi All,
My company has a little over 600 AP's, either 200 or 300 series, and quite a few of them are running in Low Power mode because they are attached to older non-POE switches. We want to track these ones down and see about swapping out the switches with newer POE ones. Is there a command that can be run in the CLI or Airwave report system that will show me all of the ones that are running below standard power? I know we can do them one at a time in the CLI, but that would take forever and is not very efficient. If there is a way to run a command or generate a report, does anyone know what it might be? I have seen silimar questions before, but never seen an answer to it.
Thanks in Advance!
Regular Contributor I
Re: AP Low Power Report
I searched found this same question as you had.  https://community.arubanetworks.com/t5/Wireless-Access/Access-Points-running-in-low-power-mode/td-p/458259
The link above talks about using a CLI command have to use the AP name.
I have made a batch CLI commands using excel to merge 2 fields one list of AP names one with the command to dump a list of information.
In ArubaOS 8.5 show ap active has the "p" flag:
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Thank you very much! I will use this then to try and determine what ones are low power then.
