Re: AP SNMP location and airwave
You could use the new naming convention with a dash and the old naming convention.  AOS 8 at the MM allows  searches that populate on partial matches.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
to get this function for AOS8 back I raised a Feature Request. If you like you can vote or add something to it.
https://innovate.arubanetworks.com/ideas/NMS-I-1455
As of ArubaOS 8.5.0.3, AP SNMP syslocation is back in the GUI when provisioning an AP under advanced:
Regular Contributor I
Superb news... Thanks for the update.
Matthew, keep in mind that it is still not in Airwave.
But the next good news is that the Feature request was sucessfull and it is planned to add it to Airwave in a next release.
