Hi all,
Firstly I am using a Juniper SRX firewall but wanted to make this my first port of call before I contact Juniper.
I have configured two interfaces on my firewall that are in the trust zone. The network on one interface, ge-0/0/0, has the wireless controller (7205 model) along with Aruba APs (various models). I am attempting to add/move APs to the network on the other firewall interface, ge-0/0/1, but am having trouble getting the APs on this network to talk to the controller on ge-0/0/0.
A separate Microsoft DHCP server is also on network ge-0/0/0 and it is successfully providing IP addresses to APs on both networks, which indicates routing and IP helpers are working fine. However, although the controller sees the APs on interface ge-0/0/1 in the AP database it registers it with the IP address of the SRX firewall instead of the IPs assigned to them by the DHCP server and has the Inactive and Dirty flags set to it.
I figured that I may need to enable/create GRE tunnel on the firewall which I attempted to do but it didn't make any difference am not sure if i did it correctly... is this the correct approach anyway?
If enabling GRE tunnel on the firewall isn't the correct approach any other suggestions on how to get this working?
Happy to provide any further details if required
