Contributor I
Re: AP reboots
Ive looked back at the original post and the text doesn't clearly show whats happening so I've attached a screenshot. The issue here is not a connectivity or networking issue. The AP boot is interrupted for some reason you can see this before the line -
APBoot 1.5.5.7 (Build 56398)
the switch is the issue I believe, or the interaction between the AP/switch for some reason.
Re: AP reboots
Have you already opened a TAC case?
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Contributor I
Re: AP reboots
Yes a TAC case is currently open.
