Re: AP's not connecting to controller
@cjoseph wrote:
If TFTP was blocked, the AP would get a timeout, not a "file not found" message.  If it was throttled, at least there would be some "T" message that indicate transmission errors.  So I don't think it is either.
True. I was able to find a similar situation someone had on the old airheads forums via a search engine, but alas you can no longer get to the post:  https://airheads.arubanetworks.com/vBulletin/archive/index.php/t-2563.html
I can't search for it either.
Zach Jennings
