Re: AP's on Master Controller
I have attached the log file from the AP with my iPad client trying to connect to the wireless network.
It looks as though the Raduis authenticates properly but I never receive an IP.....
Any windows machine is attaching fine now ...
MVP Guru
Are you using VLAN pooling ?
Can other devices get an IP address on VLAN 196 ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
The correct VLAN for the SSID is 964 which I am getting an address from on the windows devices....
MVP Guru
For some reason that device is trying to get an IP on VLAN 196, can you please check the Virtual AP config and see what's the vlans that you have in there?
Thank you
Victor Fabian
the only VLAN that is being used on that VAP is 964 ...
MVP Guru
Can you please do a show ap association client-mac <devicemac> ?
Thank you
Victor Fabian
I have attached the file
I can see in the file that the device is trying to get an IP from the 196 VLAN...... I have no idea where that is configured. Why do the windows devices connect properly with a VLAN 964 address??
thx
MVP Guru
As you can see here the device is getting VLAN 196 not 964
Are you using a NAMED VLAN pool ?
Can you please share the Virtual AP config, show wlan virtual-ap ?
show  aaa derivation-rules user
Do you allow everything for that user-role ? you should probably consider using the authenticated role as your 802.1x role .
Thank you
Victor Fabian
I have attached the wlan file
MVP Guru
Can you please do the following :
Thank you
Victor Fabian
