Highlighted
AP showing up on controller with wrong model #
I've got a new AP315 installed but it is showing up on the controller (6.5.4.3-FIPS) as an AP314. Any idea's?
Highlighted
MVP Guru
Re: AP showing up on controller with wrong model #
Haven't seen that before, can't find anything related in the release notes (for 6.5.4.8, latest in branch) either.
If you can easily upgrade to the latest version, I would give that a try so you can verify if the issue is still there, and have a better starting point for further troubleshooting. Also, 6.5.4.8-FIPS is a Conservative Release. If an upgrade is not easy, leave it at this version for now.
Please open a case with Aruba TAC Support to get this investigated.
Highlighted
Frequent Contributor II
Did you ever resolve this? We just purchased an AP-315 but the controller is showing it as a 314 and we can't provision it. The info on the unit and the box states that it's clearly a 315.
Highlighted
What version of ArubaOS?
Did you factory reset the AP?
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
OS 6.5.4.15.Yes I used the button on the back. I don’t have a serial cable to CLI into
it. Why can’t Aruba standardize on console cables? I had to buy a special
one for the 303H models, now this one as well.
Nathan Kuhl Information Technology Wyoming Seminary 570-270-2241 *** Report
all problems to the help desk: http://helpdesk.wyomingseminary.org or ext.
2240 ***
Highlighted
Does it show up on the controller?  How did you obtain it?
Highlighted
Yep, as a 314 but it’s clearly a 315. Bought through Amazon, new and sealed.
2240 ***
Highlighted
How does the OS determine an AP model? Is it by serial number or MAC address?
Highlighted
The hardware has it embedded.  If it is showing a different model, you might have something defective
Highlighted
Thanks for the help. I'll send it back.
