Highlighted
Re: AP won´t show at controller
Is that the only access point with that problem?
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Contributor II
No, i have looked after the warning and have found at least one more AP with the same errors on both controllers.
Highlighted
Contributor II
Should i open a ticket or can anyone help me with my problems?
Highlighted
Yes, if your issue is critical, a ticket with TAC should be created.
Charlie Clemmer
Aruba Customer Engineering
Highlighted
How does the cluster look when you use the command "show lc-cluster group-membership" from both of the 7210 mds? Do they show as L2 connected, or something else?
Charlie Clemmer
Highlighted
Frequent Contributor I
Are the working and none working aps in the same subnet?
Highlighted
Contributor II
(cluster1) *#show lc-cluster group-membership
Cluster Enabled, Profile Name = "LC-LAN-Controller"
Redundancy Mode On
Active Client Rebalance Threshold = 50%
Standby Client Rebalance Threshold = 75%
Unbalance Threshold = 5%
AP Load Balancing: Enabled
Active AP Rebalance Threshold = 50%
Active AP Unbalance Threshold = 5%
Active AP Rebalance AP Count = 30
Active AP Rebalance Timer = 1 minutes
Cluster Info Table
Type IPv4 Address    Priority Connection-Type STATUS
self    x.x.x.x      	  128             N/A CONNECTED (Member)
peer    y.y.y.y           128    L2-Connected CONNECTED (Leader, last HBT_RSP 82ms ago, RTD = 0.000 ms)
(cluster2) *#show lc-cluster group-membership
Redundancy Mode On
Cluster Info Table
peer    x.x.x.x           128    L2-Connected CONNECTED (Member, last HBT_RSP 67ms ago, RTD = 0.396 ms)
self    y.y.y.y           128             N/A CONNECTED (Leader)
Looks pretty normal to me.
Yes, there are working and non-working APs in the same subnet.
Highlighted
Frequent Contributor II
Did you find the solution?  I have the exact same problem. I have 6 controllers. All 7280s and have APs running on them with no problem. I get the following error?
sapm_proc_hello_req: GSM CLUSTER_AAC is not copied to assigned A-AAC, ignore HELLO
It seems my whitelist isn't being copied to all the controllers and the AP shows denied when I do a sh ap database long command
Highlighted
Contributor II
i have opened a case with Aruba and send them the same logs and the answer was, that it seems like a hardware failure in the AP, so they had send me a spare AP.
Highlighted
I'm sure that wasn't the problem. I noticed that the whitelist on my 6 controllers doesn't match. I added this entry to the MM and since all 6 controllers are part of a cluster they should sync up. We had a problem adding 4 controllers (7280s) to our exising cluster. The TAC solution was to delete the cluster and rebuild it with the new controllers added. I'm hoping that's no the solution this time. We currently have 2,000 APs running on 6.4 and migrated 1,000 over to 8.3.0.3 and are seeing these little bugs and are nervous about moving the remaining 2,000 this summer.
