Highlighted
Re: AP won´t show at controller
8.3.0.3 is older and many fixes have been put into 8.3.0.6 which is the current version.  After a bug scrub, I would plan to move to that as soon as possible this summer before migrating access points.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Frequent Contributor II
I discovered my problem. I was hard coding the SETENV master on the AP to the MM and no the VRRP IP address. This is why my whitelists weren't syncing the entry correctly. Can't wait until all of the campus is migrated over to 8.3 from 6.4 so the APs will find the information dynamically.
