Highlighted
Re: AP105 Failures
6.1.3.6 was just posted December 14th under General Availability.
After a problem is identified and a fix is proposed, it needs to be tested to ensure that it solves the problem and does not create widespread problems for others.  Some problems arise over time and it is not easy to determine if the problem is solved in the short term.  The quality of a fix increases with time...
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
ArubaOS Consolidated Release Notes
Aruba VIA ASE Solution - Configure VIA VPN
