Contributor II
Re: AP225 LACP Configuration Issue
Hi Michael,
I've set the stripping and I'm getting LACP up. However, the ports don't seem to be participating in LAG and are showing as stand-alone.
Looking at the aruba side, I'm getting:
show ap debug lacp ap-name 225-AC
AP Static Port Channel Status
Interface     Link Status  LAG Member
port channel  Up           n/a
eth0          Up           yes
eth1          Up           yes
GRE Radio Traffic Received on Enet Ports
Radio Num  Enet 0 Rx Count  Enet 1 Rx Count
0          526              7
1          5                0
Traffic Sent on Enet Ports
Radio Num  Enet 0 Tx Count  Enet 1 Tx Count
0          0                0
1          0                0
non-wifi   2                0
Can you please assist?
Many thanks in advance...
Contributor II
Just to update that I had static DHCP on the AP.
This is an issue with ArubaOS 6.3.1.3
Once AP was purged, I've provisioned it outside of etherchannel, then added it and all working fine.
