Occasional Contributor I
AP225 Wall Mounting
Hello where can I find/buy this on the photo
MVP
MVP
Re: AP225 Wall Mounting
I think you looking for a wallmount bracket. You can google this partnumbers.
JW046A (Black)
JW047A (White)
Kind Regards Marcel Koedijk
HPE ASE Flexnetwork | ACMP | ACCP - Was this post usefull, Kudos are welcome.
 I have already mounting bracket, but I'm looking for those two types of caps
MVP
MVP
That is not a exchangable part. Maybe you can try contact TAC support.
Aruba
f you have an issue with these mount bosses (did they come loose?), you can rely on our product warranty to get the unit (AP) replaced.
/Onno
I have received this access point from an acquaintance, and I think it is already 3/4 years old. I do not know if there is still a guarantee, because I miss those two caps that I have to put on before I can click on that bracket.
Might help to post a picture of the back of the AP you have. Not sure how those could have been removed.
Jerrod Howard
Distinguished Technologist, TME
Hello these are the two caps (brackets I think) that are missing.
Aruba
Yeah, that's not something that can be repaired.
Assuming these were not ripped off, warranty would cover that, but give that you're not the original owner of the product, the Aruba limited lifetime warranty amy not apply.
/Onno
Is it still possible to have it repaired or not?
