Anyone having problems with the above?
The AP will:
Upgrade the image, not the CPSec - I tried with CPSec disabled, too.
Display under Infrastructure, AP database, - not provision.
Found the following Bug ID on 8.4.0.0 Release Notes - it does not mention version.
175140 Symptom: AP-325 access points were not coming up on the managed device. This issue was resolved by fixing IP reassembly code. Scenario: This issue occurred because of an issue in the reassembly code of the managed devices. This issue was observed in Mobility Master Virtual Appliances running ArubaOS 8.0.0.0 or later versions.
Worked fine with 8.3.0.5-FIPS
