MVP Expert
AP374 and a 4x4 D608 ANT
Hey @onno
A customer asked me a question...
If they have an AP374 and a 4x4 D608 ANT, can two be connected to 2.4GHz and two be connected to 5GHz? For 2x2 2.4GHz and 2x2 5GHz using a single D608? They would only be doing this for test purposes. The final solution being all $ connected to 5GHz and a separate ANT for the 2x2 2.4GHz.
Looking at the makeup of the 4x4 D608 ANT, I said I would not recommend it but I would verify with you guys if it could be done or not.
Aruba
Re: AP374 and a 4x4 D608 ANT
Yes, you could do this.
Make sure to connect antenna ports 0 and 1.
That means you're leaving antennas 2 and 3 on 5GHz unconnected.
Not recommended (we have no way to disable 3SS and 4SS operation), but it'll work. They should terminate the unused ports with dummy loads.
/Onno
MVP Expert
Thanks man. As for the ANT.. it has 4 ports.
-45
+45
V
H
How should those correspond to the 374 ports 5GHz 0,1 and 2,4GHz 0,1?
Thanks again @onno
Aruba
Use +/- 45 for one radio, V and H for the other
/Onno
MVP Expert
Thanks again @onno
