Highlighted
Re: ARUBA 3600 controller doesn't detect AP 61
It doesn't appear, so I can't do it. I can only see in the Configuration> Wireless> AP Installation one of them, the one with IP 192.168.2.32, not the one I'm having trouble with (192.168.2.33).
Highlighted
Type "show ap-group" and paste the output into here..
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
ArubaOS Consolidated Release Notes
Aruba VIA ASE Solution - Configure VIA VPN
Highlighted
(Aruba3600) #show ap-group
AP group List
Name              Profile Status
C.C. Vinyagrande
default
Vinagrande
Total:3
Highlighted
Do this:
config t
ap-group Vinagrande
write memory
It is possible that your Vinagrande has a space in it.
Highlighted
I introduced the commands, wait a few minutes... but still have the same problem, I can only see one AP to be provisioned.
Anyway the problem is not with the Vinagrande one (192.168.2.32), the one i cannot see in the web tool is the other one we didn't see on the system log (192.168.2.33).
Thank you for your help
Highlighted
Okay.  On the commandline, run this command to see if any traffic is being sent to the controller from that access point:
show datapath session table 192.168.2.33
run it over and over again to see if there is any traffic,
Highlighted
I tried the command and it appeared like this several times:
(Aruba3600) #show datapath session table 192.168.2.33
  Source IP     Destination IP  Prot SPort DPort  Cntr Prio ToS Age Destination TAge Flags
After that I tried a ping from the controller (192.168.2.111) to the AP, and then the command displayed the information below displayed.
(Aruba3600) # ping 192.168.2.33
Press 'q' to abort.
Sending 5, 100-byte ICMP Echos to 192.168.2.33, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 0.588/0.9588/2.369 m        s
192.168.2.33    192.168.2.111   1    35    0      0    0    0   1   local        1    F
192.168.2.33    192.168.2.111   1    34    0      0    0    0   1   local        1    F
192.168.2.33    192.168.2.111   1    33    0      0    0    0   1   local        1    F
192.168.2.33    192.168.2.111   1    32    0      0    0    0   1   local        1    F
192.168.2.33    192.168.2.111   1    31    0      0    0    0   1   local        1    F
192.168.2.111   192.168.2.33    1    31    2048   0    0    0   1   local        1    FYC
192.168.2.111   192.168.2.33    1    35    2048   0    0    0   1   local        1    FYC
192.168.2.111   192.168.2.33    1    34    2048   0    0    0   1   local        1    FYC
192.168.2.111   192.168.2.33    1    33    2048   0    0    0   1   local        1    FYC
192.168.2.111   192.168.2.33    1    32    2048   0    0    0   1   local        1    FYC
Highlighted
Unfortunately, that means that access point is not even trying to contact the controller.  The data you were seeing is just pings back and forth.  You might want to try connecting it to the old controller and seeing if it is statically configured to connect to that controller.
Highlighted
And what if I'm not able to use the old one? Can I restart the AP to fabrics?
Highlighted
Unfortunately, the AP61 does not have a console port.  You would have to get a "Y" cable to reset it.  Please see information here:  http://community.arubanetworks.com/t5/Access-Points-and-Mesh-Routers/AP-61-Console-to-clear-the-pre-configuration/td-p/19028
View solution in original post
