Highlighted
Access Points Inactive and Unlicensed
Hi Guys!
I'm new to Aruba and am having some problems during my testing phase.
We have designed a wireless solution for small branch locations, with the MM and a MC cluster in a datacenter.
We've setup the connectivity between a branch and the datacenter. The AP connects to the MC's through DHCP and is seen online in the MM.
We can provision it but after the reload it shows up as inactive and unlicensed in the ap database. I've tried disabling control plane security but to no avail.
(XXX-DC-MC02) #show ap database
AP Database
Name                  Group               AP Type  IP Address  Status    Flags  Switch IP     Standby IP
XXX-AP-V1-02  AP-GRP-XXX  305      10.xx.xx.51   Up 6m:9s  2IL    10.xxx.xxx.232  0.0.0.0
I have installed the licenses on the MM. (see attached)
I have 127 AP and PEF licenses installed. the total amount is higher due to me not being able to delete the expired trial licenses.
The AP keeps on rebootstrapping and rebooting every 8 minutes or so.
Could you guys please point me in the right direction as I am very confused as to why the AP stays unlicensed.
Many thanks,
I've attached some relevant logging from "ap debug system-status" and "show log all 100"
(XXX-DC-MC02) #show ap debug system-status ip-addr 10.xx.xx.51
Rebootstrap Information
Date       Time     Reason (Latest 10)
1969-12-31 16:01:27 Switching to LMS 10.xxx.xxx.231: HELLO-UNLICENSED. Last Ctrl message: HELLO len=1397 dest=10.xx.xx.232 tries=2 seq=0
1969-12-31 16:01:30 New connection, Changing to LMS (10.xx.xx.231) [cur_lms_index: 1, event: REDUN_EVENT_TUNNEL_UP, cur_state: REDUN_STATE_TUNNEL_LMS, function: redun_tunnel_up(5164)]
1969-12-31 16:01:33 Rcv new config, Changing LMS to 10.xx.xx.232 cur_lms_index:1 event:REDUN_EVENT_LMS_CONFIG cur_state:REDUN_STATE_UP (redun_check_config:4715)
1969-12-31 16:01:37 New connection, Changing to LMS (10.xx.xx.232) [cur_lms_index: 0, event: REDUN_EVENT_TUNNEL_UP, cur_state: REDUN_STATE_TUNNEL_LMS, function: redun_tunnel_up(5164)]
1969-12-31 16:01:44 New connection, Changing to LMS (10.xx.xx.232) [cur_lms_index: 0, event: REDUN_EVENT_TUNNEL_UP, cur_state: REDUN_STATE_TUNNEL_LMS, function: redun_tunnel_up(5164)]
1969-12-31 16:01:59 Switching to LMS 10.xx.xx.231: HELLO-UNLICENSED. Last Ctrl message: HELLO len=1397 dest=10.xx.xx.232 tries=2 seq=0
1969-12-31 16:02:02 New connection, Changing to LMS (10.xx.xx.231) [cur_lms_index: 1, event: REDUN_EVENT_TUNNEL_UP, cur_state: REDUN_STATE_TUNNEL_LMS, function: redun_tunnel_up(5164)]
1969-12-31 16:02:06 Rcv new config, Changing LMS to 10.xx.xx.232 cur_lms_index:1 event:REDUN_EVENT_LMS_CONFIG cur_state:REDUN_STATE_UP (redun_check_config:4715)
1969-12-31 16:02:09 New connection, Changing to LMS (10.xx.xx.232) [cur_lms_index: 0, event: REDUN_EVENT_TUNNEL_UP, cur_state: REDUN_STATE_TUNNEL_LMS, function: redun_tunnel_up(5164)]
1969-12-31 16:02:17 New connection, Changing to LMS (10.xx.xx.232) [cur_lms_index: 0, event: REDUN_EVENT_TUNNEL_UP, cur_state: REDUN_STATE_TUNNEL_LMS, function: redun_tunnel_up(5164)]
Nov 26 18:53:44  cfgm[3940]: <399838> <3940> <WARN> |cfgm|  LmsHeartBeatResultAction: State(CONNECTINPROGRESS:UPDATE SUCCESSFUL:CFGID-115:PEND-115:INITCFGID:0) FD=27:Cannot heartbeat with the master.
Nov 26 18:54:05  cfgm[3940]: <399816> <3940> <ERRS> |cfgm|  handle_read: State(READY:UPDATE SUCCESSFUL:CFGID-115:PEND-115:INITCFGID:0) FD=27:Failure receiving heartbeat response header information Res                                     ult=-1 Err=Connection timed out
Nov 26 18:59:45  stm[4061]: <305038> <4061> <WARN> |stm|  No available license type IDS for AP XXX-XXX-AP-V1-02
Accepted Solutions
Highlighted
Re: Access Points Inactive and Unlicensed
Hi Joseph,
I still had the RFP licenses enabled from when we were testing, I've disabled them and now the AP wil license correctly.
Thank you for your help!
Kind Regards,
Michael.
View solution in original post
All Replies
Highlighted
Remove the RFP license if you have any more than 64 APs.  If not, the RFP license will not allow you to add anymore.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
ArubaOS Consolidated Release Notes
Aruba VIA ASE Solution - Configure VIA VPN
Highlighted
Highlighted
Hi Joseph,
These licenses are expired trial licenses, can these expired lic's interfere with active ones?
Highlighted
Hi Joseph,
Kind Regards,
Michael.
