Highlighted
Access point firmware check
We have Aruba 650 and 7010 controllers with accesspoint model AP103. We need to check the firmware version of the acess points. From where can i get the firmware version ? I did check in the controllers but unable to find the place.
Chamila.
Accepted Solutions
Highlighted
MVP Guru
Re: Access point firmware check
The firmware of the APs will be exactly the same firmware as the controller. The APs will download the firmware version from the controller they are terminated on.
#show version
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
View solution in original post
All Replies
Highlighted
MVP Guru
#show version
