Activating RF Protect on Existing Wifi Network
Hi all,
Quick question. I have some RF Protect licenses on my aruba mobility master however they are not in use. I have had an active wifi environment for a while and have only just realised this. Am i required rto activate them to the AP's specifically or is there a process for it?
Re: Activating RF Protect on Existing Wifi Network
How to add licenses is here:  https://www.arubanetworks.com/techdocs/ArubaOS_83_Web_Help/Web_Help_Index.htm#LicenseGuide/install_MMaster.htm?Highlight=adding%20licenses
Adding a new type of license will require a reboot of the MD where the licenses are applied.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Hi thanks for your help, however im not having issues with adding licenses.
The licenses have been added however all my RF Protect licenses are idle.
Do I have to specifically apply some command to kick them into use or is this something to do with the AP's?
Thanks all for your help
