Highlighted
Airwave PAPI Problem
Highlighted
Re: Airwave PAPI Problem
It needs to be checked from the CLI on why it is stopped. Sometimes we would have to kill the process and restart based on log.
I would suggest opening a TAC case.
Vishnu
If my post helped you, don't forget to give kudos ;)
Highlighted
 * The PAPI handler server was kept restarting due to hostname unspecified in /etc/hosts file.  information.
* Added the hostname of the server in /etc/hosts file and restarted all the services.
* Switched to AMON preferred and the PAPI server is stable now.
this is the soultion , i know papi is message between controlle and airwave to make RF -plans so how it related to hostname of airwave ??
why we must configure airwave hostname in /etc/hosts ???
Highlighted
When we configure the host name on GUI Ampsetup --> Network page, it will get added automatically to /etc/hosts.
Vishnu
