Using 6.4.4.18 and AP-105's. Alaris Infusion pumps state that they support 802.11 a/b/g/n. We see that the pumps attempt to connect at a-HT or g-HT and always fail. Removing HT from the SSID and the pumps connect. A recommendation from the manufacturer (Care Fusion), to enable single chain legacy, which does not seem to be supported any longer. Any thoughts?
