Occasional Contributor I
Allow Specific Device To be Routed
Hi...we have a device (Kramer Via Connect Pro) on our corporate network (172.16.0.0....vlan1). All users on our Corporate wifi can connect to it, as they should.
We have a Guest network (10.10.0.0....vlan 100). Of course they cannot connect to this device because it's IP is on the 172.16.0.0 network.
Is it easy to allow users on our Guest network to connect to the specific IP address of that specific device? Would it be safe? Would it just be a routing issue?
Any help setting this up would be appreciated. Thanks.
Re: Allow Specific Device To be Routed
We would need a diagram of your network to answer that.  If your guest network is natted or unroutable it might not be possible.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
