Re: Android phones can't get IP on reconnect...
yes
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Frequent Contributor I
(controller) #show rights guest
Derived Role = 'guest'
 Up BW:No Limit   Down BW:No Limit
 L2TP Pool = default-l2tp-pool
 PPTP Pool = default-pptp-pool
 Periodic reauthentication: Disabled
 DPI Classification: Enabled
 Web Content Classification: Enabled
 ACL Number = 4/94
 Max Sessions = 65535
 Check CP Profile for Accounting = TRUE
Application Exception List
Name  Type
Application BW-Contract List
Name  Type  BW Contract  Id  Direction
access-list List
Position  Name                           Type     Location
1         global-sacl                    session
2         apprf-guest-sacl               session
3         validuserethacl                eth
4         acme-block-1918              session
5         ra-guard                       session
6         acme-block-dhcp              session
7         acme-block-linklocal         session
8         acme-block-management        session
9         acme-block-local-debug-page  session
10        acme-guest-dns-nat           session
11        acme-guest-http-nat          session
12        acme-guest-icmp-nat          session
13        acme-guest-ios-gmail-nat     session
14        acme-guest-gplay-nat         session
15        acme-guest-ipsec-nat         session
16        acme-guest-gaming-nat        session
17        cplogout                       session
18        acme-drop-any                session
19        acme-drop-log                session
global-sacl
Priority  Source  Destination  Service  Application  Action  TimeRange  Log  Expired  Queue  TOS  8021P  Blacklist  Mirror  DisScan  ClassifyMedia  IPv4/6  Contract
apprf-guest-sacl
ip access-list eth validuserethacl
  permit any
acme-block-1918
1         any     10.0.0.0 10.255.255.255     any                   deny                             Low                                                           4
2         any     172.16.0.0 255.248.0.0      any                   deny                             Low                                                           4
3         any     192.168.0.0 192.168.255.25  any                   deny                             Low                                                           4
ra-guard
1         user    any          icmpv6 rtr-adv                 deny                             Low                                                           6
acme-block-dhcp
1         user    any          udp 68                deny               Yes           Low                                                           4
1         any     169.254.0.0 255.255.0.0  any                   deny                             Low                                                           4
1         any     controller   any                   deny               Yes           Low                                                           4
1         user    localip      any                   deny                             Low                                                           4
acme-guest-dns-nat
1         user    74.82.42.42  svc-dns               src-nat pool acme-av1-nat-pool                           Low                                                           4
2         user    8.8.8.8      svc-dns               src-nat pool acme-av1-nat-pool                           Low                                                           4
3         user    8.8.4.4      svc-dns               src-nat pool acme-av1-nat-pool                           Low                                                           4
acme-guest-http-nat
1         user    any          svc-https               src-nat pool acme-av1-nat-pool                           Low                                                           4
2         user    any          svc-http                src-nat pool acme-av1-nat-pool                           Low                                                           4
acme-guest-icmp-nat
1         user    any          svc-icmp               src-nat pool acme-av1-nat-pool                           Low                                                           4
1         user    any          tcp 993               src-nat pool acme-av1-nat-pool                           Low                                                           4
2         user    any          tcp 465               src-nat pool acme-av1-nat-pool                           Low                                                           4
1         user    any          tcp 5228               src-nat pool acme-av1-nat-pool                           Low                                                           4
1         user    any          udp 4500               src-nat pool acme-av1-nat-pool                           Low                                                           4
2         user    any          udp 500                src-nat pool acme-av1-nat-pool                           Low                                                           4
3         user    any          tcp 4500               src-nat pool acme-av1-nat-pool                           Low                                                           4
4         user    any          tcp 500                src-nat pool acme-av1-nat-pool                           Low                                                           4
1         any     any          udp 2053                src-nat pool acme-av1-nat-pool                           Low                                                           4
2         any     any          tcp 10050               src-nat pool acme-av1-nat-pool                           Low                                                           4
3         any     any          tcp 9293                src-nat pool acme-av1-nat-pool                           Low                                                           4
4         any     any          udp 50000               src-nat pool acme-av1-nat-pool                           Low                                                           4
5         any     any          tcp 1119                src-nat pool acme-av1-nat-pool                           Low                                                           4
6         any     any          tcp 3724                src-nat pool acme-av1-nat-pool                           Low                                                           4
cplogout
1         user    controller   svc-https               dst-nat 8081                           Low                                                           4
acme-drop-any
1         any     any          any                   deny                             Low                                                           4
acme-drop-log
1         any     any          any                   deny               Yes           Low                                                           4
Expired Policies (due to time constraints) = 0
(controller) #
Mike mclarke says, "any any svc-dhcp permit" needs to be at the top of that, otherwise you will have DHCP problems like you have been having.  None of your rules explicity allow DHCP when a user re-associates later.
Ohh - so they are getting DHCP in the guest-logon role, but it's being blocked when they reassociate before their session times out?
Makes sense.
The guy before me has the deny udp 68 rule so guests can't give out DHCP.  Is that even effective though?  I don't believe I allow guest to guest communication.  Can I just delete that rule and allow DHCP at the top of the ruleset?
You can put the udp 68 deny rule first, then the any any svc-dhope permit rule next.
Done.  I'm guessing that's going to resolve the issue.  Thanks for the blazing fast replies once again!
Yeah, what happens is that when the devices wake up they remember their ip details and then do a unicast RENEW to the dhcp server, which you have blocked.
ACCP, ACCX #817, ACMP, ACMX #294
Okay, that makes a lot of sense.
Thanks for your help!
