Ap-303H-MNTW Mount with Coax
Just curious if anyone has tried to use this mount with the keystone jacks for installing coax with the 303H's.  If so was there any caveats or any special keystone coax connectors that did or didn't work if it wasn't just a standard keystone connection.
TIA,
Brady
