Highlighted
Highlighted
Re: Aruba 225 LED Status
I have the same problem with my 225 that's running through a powered 8-port switch. However, when I tried a (much) shorter ethernet cable through the same switch it worked fine.
So here's my question: Is it my endings that are at fault, or did the kinks I  inadvertantly put in my cable somehow affect the power?
Highlighted
I think only you have the answer to your question...
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
