Highlighted
Occasional Contributor I
Aruba AOS8 - AP system location
I can't find an option, where to setup AP SNMP system location in AOS 8. I have 7220 "standalone".
I read a user guide 8.4.0.0 in section Configuring an AP using the WebUI and it says in point 9:
9. (Optional) Define the AP name or SNMP location. The AP list section displays current information for an AP, and allows you to define additional parameters for your AP, such as AP Name, SNMP System Location.
BUT I don't know, where to fill in. In provision setup (see attached file) i don't see an option.
Or am I on wrong page?
Thanks for reply.
TK
Accepted Solutions
Highlighted
Re: Aruba AOS8 - AP system location
If I had to guess, I think it is gone forever.  Quite a few people were confused by it in the past and few people actually used it.  The name of the AP probably offers the best opportunity to provide the location, and it appears in the list of APs for easy viewing.  The AP System Location only appeared on the provisioning page and the provisioning page was busy enough....
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
ArubaOS Consolidated Release Notes
Aruba VIA ASE Solution - Configure VIA VPN
View solution in original post
All Replies
Highlighted
You are not wrong.  It is no longer there.  I will alert the Technical Publications department to remove it.
Highlighted
Thanks for reply cjoseph:
so AP SNMP system location is no longer available in AOS8?
Soooo instead of contacting Technical Publications department. Can you contact programmers, that they give back that option? :-D
Highlighted
Highlighted
So, I figured out that I can config syslocation via CLI:
configure terminal
clear provisioning-ap-list
provision-ap
read-bootinfo ap-name <NAME>
show provisioning-ap-list
copy-provisioning-params ap-name <NAME>
show provisioning-params
syslocation "STRING"
reprovision ap-name <NAME>
Highlighted
You certainly can, but how do you retrieve them in a way that is convenient without Airwave?
Highlighted
We retrieve through zabbix. Then we have our application that display the AP on the map with that information:
In syslocation we have something like this>
XX.4213475N, XX.8992411E; strop vnitrni prostor; Lodenice; Ptacka parc.XXX; XXX 01; MB
GPS; AP location; building name; address; ZIP code; city
It work quiet well.
Highlighted
That sounds like you have a workable solution.
Highlighted
As of ArubaOS 8.5.0.3, provisioning an AP's SNMP system location has returned to the GUI:
