Highlighted
Re: Aruba AP 205 with 7010 Mobility Cont. - AP Drop Problem
We are using 2 difference switch for 9 ap ;
First sw : 2 Ap here and 1 ap normal working, 1 broken ap.
Second sw : 7 Ap here. 4 normal working , 3 broken ap.
Highlighted
up!
Highlighted
This problem solved but nothing change on config or topology. Case engineer can't understand it,  me too.
It was solved .
View solution in original post
