Occasional Contributor I
Aruba AP-220 Universal Ceiling Grid Mounting Kit
What's the equivalent Cisco AIR-AP-BRACKET universal mounting (https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-3/b_cisco_aironet_series_2800_3800_access_point_deployment_guide/b_cisco_aironet_series_2800_3800_access_point_deployment_guide_chapter_010.html) to Aruba ap-220?
Are there any similar options available? Attached are the pics for reference.
Thank you.
CP
MVP Guru
Re: Aruba AP-220 Universal Ceiling Grid Mounting Kit
The mounting options are described in the Ordering Guide for each Access Point. For the AP-220 series, the guide can be found here. The AP comes with standard ceiling grid mounts for flat rails. From the ordering guide, you can see there are options for wall/ceiling mount, a box-style mount (box behind the AP), less standard grid and industrial rail.
If you want to see images of the mount kits, you can check the hardware install guides which are here. Also, you should consult your Aruba partner if you need assistance in selecting the right mount kit.
Thanks, Herman.
CP
