Aruba AP not broadcasting SSID
This thread has been viewed 23 times
  • 1.  Aruba AP not broadcasting SSID
    Posted Sep 22, 2019 11:24 PM
    Dear All,
    I was setting up a Aruba VMC.I got eval license for the VMC.
    I create a WLAN and mapped the AP group to the WLAN profile.
    But the AP is still not broadcasting the SSID.When I check the ap database it is showing IL flag.
    AP Database
    Name Group AP Type IP Address Status Flags Switch IP Standby IP
    AAP1_1A Test 215 192.168.194.128 Up 4m:31s IL 192.168.194.50 0.0.0.0
    License usage.
    AP Licenses
    Type Number
    AP Licenses 10
    RF Protect Licenses 10
    PEF Licenses 0
    MC-VA Licenses 10
    MC-VA country SG
    Controller License True
    Overall AP License Limit 0
    AP Usage
    Type Count
    Active CAPs 0
    Standby CAPs [Counted Against Total] 0
    Active RAPs 0
    Remote-node APs 0
    Active MUX 0
    Active PUTN 0
    Total APs 0
    Remaining AP Capacity
    Type Number
    CAPs 0
    RAPs 0
    Can anyone help me out on this.
  • 2.  RE: Aruba AP not broadcasting SSID
    MVP EXPERT
    Posted Sep 23, 2019 12:51 AM
    Try to install the PEF (policy enforcement firewall), this one is required when you use custom roles.
  • 3.  RE: Aruba AP not broadcasting SSID
    Posted Sep 23, 2019 01:03 AM
    Yes just did that..it fixed it :) thanks for the support.
