Contributor II
Aruba Instant 8.4 is Not Stable for IAP-315
I am Testing "ArubaInstant_Hercules_8.4.0.0_68230-AP" it is not stable
  • DNS query not resolving any DNS server. but ICMP is working
  • Unable to connect  Instant login when network managed DHCP
  • Some times working properly
Re: Aruba Instant 8.4 is Not Stable for IAP-315
We need more info to be able to assist.
What is the client device/version that you're testing with? What security mechanism is the SSID configured for? How is the AP and SSID connected to your wired infrastructure? What security role does your connected user get upon connecting to the SSID successfully?
Charlie Clemmer
Aruba Customer Engineering
Contributor II
IAP-315
OS Version - 8.4.0.0._682230
two SSIDs security levels: enterprise(WPA2) and Personal(WPA2 Personal)
Single Access Point connected directly to ISP router power using POE injector
Security Roles working properly
Now It is working properly. I think it is due to NAT error or ARP
We do not have enough information to understand what is wrong.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Contributor II
Now System works fine. here attached system configuration for your reference.
https://drive.google.com/file/d/1qbUtyb_iViM3HYmAUldB1byXi_qkZr9P/view?usp=sharing
