Highlighted
Occasional Contributor I
Aruba Instant, strange datarate flap
Hello
I am experiencing strange behavior at one client premises. According to Instant dashboard client data rate/speed is flapping (see attachment), same time RSSI and SNR are stable. First, I thought that this is some driver issue, but seems like same pattern is seen on Windows and Android devices.
Has anybody seen same behavior and, what has been the cause?
What I have done:
  1. Check that no co-channel interferents there.
  2. Spectrum check, no spikes or other non 802.11 interferes there.
  3. IAP 8.6 and 8.7 firmware tried.
Thanks!
