Highlighted
Re: Aruba OS 8 Mobility Controller Cluster IP
You can use show lc-cluster vlan-probe status to see if the controllers don't see each other on every VLAN you specified (specifying means not adding it to ignored VLANs:)
Highlighted
Cluster VLAN Probe Status
Type IPv4 Address    REQ-SENT REQ-FAIL ACK-SENT ACK-FAIL REQ-RCVD ACK-RCVD VLAN_FAIL CONN-TYPE START/STOP
peer    172.16.0.252        0        0        0        0        0        0         0       N/A     0/  49
You don't seem to see each other.
But if you respond to ping between MCs
