Hi Community,
I have a problem with provision RAP
IKE XAuth client UP failed 10.1.34.130 (External 10.1.34.130)Oct 9 16:28:17 isakmpd[3614]: <103103> <3614> <WARN> |ike| 10.1.34.130:59776-> IKE SA Deletion: IKE2_delSa peer:10.1.34.130:59776 id:3344822301 errcode:ERR_IKESA_CLEARED saflags:0x51 arflags:0x9
Is this a new RAP or an existing RAP? Have you provisioned any other RAPs without issues? Have you created all the required RAP including IP Pools, RAP whitelist etc?
Please feel free to share any information on your deployment.
New AP. Initially Provisioned as CAP and Covered to RAP.
DHCP pool and Provision as a Certificate-based.
Connected to a MM/MD or Standalone? What AP model and AOS version? Given the limited information, it might be worth you reviewing the attached.
Attachment(s)
Deployed as Standalone
Aruba Mobility Controller: 7030
Aruba OS 8.7
AP model: 303
Sounds a bit like my issue here (also unresolved):
https://community.arubanetworks.com/t5/Wireless-Access/RAP-Troubleshooting/td-p/676650
My problem solved after configuration shared secrets in VPN setting
Weird, we also have a shared secret configured...
