Hi Guys,
My first post having been reading the useful airheads community articles recently.
I have recently been testing 2x 7240XM in a cluster connecting to a MM-VA (running 8.6.0.2). These are being tested with a view to replacing the current 2x 7204 running 6.5.1.9. I have much of the setup working as expected but have a few questions:
- Can a guest WLAN have a password setup to connect to the SSID and then the authentication page requesting username and password credentials? (The current controllers in place allow this but I have not managed to find how to do this on 8.6.0.2).
- Can the guest provisioning portal be restricted to only be accessed by certain individuals? (Currently, as a RADIUS server is configured for employees to log in to the Employee SSID this means the guest provisioning portal is also allowing all employees to authenticate and log in and create users - I want to restrict this to say the IT department only.
- When connecting to the Guest SSID, the redirect takes the user to a http://www.msftconnecttest.com/redirect?cmd=redirect&arubalp=12345 when connecting from a Windows machine only, suggesting a certificate error however this does not occur on iPhones, iPads etc. As iPhone, iPad users connect immediately I believe a certificate is not required however am happy to learn about this.
Any help on the above is most appreciated.
Kind regards,
bc
