Highlighted
Frequent Contributor II
Re: ArubaOS 8.x MM-VA sizing
Whats about Service?
If i use 1 VM with 2 MM-VA-50 Licenses. Do i need 2x FC 24/7 SCV ?
Highlighted
Hi
AFAIK you should have support for all the licenses, not just a part of them.
Cheers, Frank
AirHeads MVP |AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
Highlighted
Occasional Contributor I
Yes
