Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Highlighted
Contributor II
ArubaOS 8.x where can I view AP specific settings?
I can make AP specific settings from cli under a node. Where can I view those settings. If I try 'show ap-name <ap> '  I get the error "commands need to be executed on ..."
Can't find settings on webui or cli. Thank you.
Accepted Solutions
Highlighted
Moderator
Re: ArubaOS 8.x where can I view AP specific settings?
on mm you have to go into the managed network and use
show configuration effective | begin "ap-name <ap>"
or mdconnect to the MD where you know the config ended up
and use "show ap-name <ap>" there
View solution in original post
All Replies
Highlighted
Moderator
