Re: ArubaOS Software Feature Matrix
Regular Contributor I
perfect, i didnt expect under EOL matrix this info,  thanks,
so AP125 is last supported in OS 6.4 , that's fine for the moment.
thanks
ben
I can't find the file either. Could you get it?
it's not a file , it's just a table-matrix where you can find information until which ArubaOS version an AP is supported , e.g. in my case AP125 i wanted to know which will be the latest ArubaOS version to support this AP125 , and then you open the above matrix link and you see "last supported ArubaOS version" in my case ArubaOS 6.4.
MVP Expert
Actually, this certainly is (was?) a (.xls) file.
I've attached the file that was available for download from the support site. This file is a year old so doesn't include the newest OS'es and I'm not sure whether it has been replaced with anything so take this 'as is'.
Rename the .txt to .xls to get a working file.
Koen (ACMX #351 | ACDX #547 | ACCP)
