Auto provisioned Certificates
  • 1.  Auto provisioned Certificates
    Posted Jan 17, 2019 04:32 AM
    I have just swapped over from manual to auto-cert provisioning (V8.3) and it is all working as expected except on the whitelist, all the APs are showing as "factory-cert" when I was expecting them to change to "switch-cert".
    Normal or bug? If the latter I'll raise a case.
  • 2.  RE: Auto provisioned Certificates
    Posted Jan 17, 2019 06:00 AM
    That is the cert-type entry.  What is the state?
  • 3.  RE: Auto provisioned Certificates
    Posted Jan 17, 2019 06:16 AM
    Yeah, they are all working fine - are accepted and approved, I was just expecting them to come up as having a switch cert rather than still using their factory certs.
  • 4.  RE: Auto provisioned Certificates
    Posted Jan 25, 2019 07:42 AM
    Just to complete the thread, I logged it with TAC and got the following:
    I understand that you have recently enabled Auto cert provisioning on the controller and it working fine. However, the whitelist entries show as Factory cert when you expected it to be switch cert. This is normal with APs that come with factory certificate. All new APs come up with factory certificate installed on them. Only the legacy APs don’t have factory certificate and would get the certificate from the controller (switch cert).
