Re: Automatic provisioning of APs
Interesting, thanks for the reply. Is this the synatx for ap?  If so, how do you specify group, do  you use ap-regroup?
whitelist-db cpsec add mac-address  <mac>
ap-regroup wired-mac  <mac>
To change the whitelist for an AP, use this command instead.
whitelist-db cpsec modify mac-address
The entire command will look like what I have below. If either the AP group or AP name does not need to change, just type the existing group/name with the command.
whitelist-db cpsec modify mac-address <ap-wired-mac-address> ap-group <new ap group> ap-name <new ap name>
