Highlighted
Best practice to Split VC
I have a VC with 110 IAPs. I meet some issues (like VC does not change IAP when the IAP-host going down).
So I want to split VC in two (50 and 60 IAPs).
I have try to do it with 10 IAPs but I see PAPI exchange between
the both VCs.
To create the second VC, I have put one IAP in standalone, change admin vlan on switch and reset it. When was good, I have change admin vlan and reboot the 9 other IAP.
The environment is manage by Airwave.
I did not find technote / guide or post that explain how to do it.
Thank you.
Sébastien.
