Highlighted
Re: Best way to force guests to use a proxy?
So, the user logs in , we get the capitve portal, which is successful but its not assigning our test user 'guest2010' into the guest profile and using the guest-web policy that has our NAT rule
(P7FUJI01) #show user
Users
IP MAC Name Role Age(d:h:m) Auth VPN link AP name Roaming Essid/Bssid/Phy Profile
10.36.2.246 00:24:2b:c1:47:43 guest-logon 00:00:38 00:24:6c:c3:1f:91 Wireless PincG/00:24:6c:b1:f9:11/g-HT guest-aaa-profile
10.36.3.253 00:1c:bf:23:51:aa guest-logon 00:00:54 00:24:6c:c3:1f:91 Wireless PincG/00:24:6c:b1:f9:11/g guest-aaa-profile
10.36.3.250 00:1e:c2:c3:8a:ce guest2010 guest 00:00:46 Web 00:24:6c:c3:1f:91 Wireless PincG/00:24:6c:b1:f9:19/a-HT guest-aaa-profile
User Entries: 3/3
(P7FUJI01) #show acl hits
User Role ACL Hits
Role Policy Src Dst Service Action Dest/Opcode New Hits Total Hits Index
guest guest-blacklist any any any permit 28 28 15801
guest-logon guest-control user any svc-dhcp permit 0 1 15775
guest-logon guest-control user DNSServers svc-dns permit 0 17 15776
guest-logon captiveportal user mswitch svc-https dst-nat 8081 0 8 15778
guest-logon captiveportal user any svc-http dst-nat 8080 0 2 15779
guest-logon any any 0 deny 9 31 15781
Port Based Session ACL
validuser any any any permit 0 86 7954
deny-corporate-to-mgmt any controller-vrrp svc-syslog permit 8 1157 8266
deny-corporate-to-mgmt inband-ip inband-ip any permit 1365 646665 8267
deny-corporate-to-mgmt inband-ip vrrp-mcast any permit 0 8881 8268
deny-corporate-to-mgmt airwave inband-ip any permit 20 11660 8270
deny-corporate-to-mgmt guest-users inband-ip svc-http permit 0 213 8271
deny-corporate-to-mgmt any inband-ip svc-papi permit 13 7427 8275
deny-corporate-to-mgmt any inband-ip svc-gre permit 0 4 8276
deny-corporate-to-mgmt any inband-ip svc-http permit 0 115 8280
deny-corporate-to-mgmt any inband-ip svc-syslog permit 0 11 8284
deny-corporate-to-mgmt any inband-ip svc-icmp permit 0 2 8285
deny-corporate-to-mgmt any any 0 deny 34 3353 8286
Port ACL Hits
ACL ACE New Hits Total Hits Index
(P7FUJI01) #
Highlighted
Captive Portal Authentication Profile
Users
User Entries: 3/3
User Role ACL Hits
Port ACL Hits
(P7FUJI01) #
So users in a captive portal are assigned roles based on the Captive Portal authentication profile assigned to that captive portal. In the Captive Portal authentication profile, there is a server group that says the database you are using to authenticate users, as well as a Default Role, that decides what role users who are authenticated will be placed in. Find your captive portal authentication profile under Configuration> All Profiles> Wireless> Captive Portal Authentication Profile. Change the default role to be the one you want the user to be in AFTER authentication.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Thakns, ive just checked that captiveportal role and its set to 'guest' which is correct, i also checked that guest-web firewall policy is associated to userrole guest..
Highlighted
show rights guest
Okay, let's see "show rights guest", then.
Highlighted
(P7FUJI01) #show rights guest
Derived Role = 'guest'
Up BW contract = 1Mbps (1000000 bits/sec) Down BW contract = 1Mbps (1000000 bits/sec)
L2TP Pool = default-l2tp-pool
PPTP Pool = default-pptp-pool
Periodic reauthentication: Disabled
ACL Number = 3/0
Max Sessions = 65535
access-list List
Position Name Location
1 guest-blacklist
2 cplogout
3 guest-web
4 vpnlogon
guest-blacklist
Priority Source Destination Service Action TimeRange Log Expired Queue TOS 8021P Blacklist Mirror DisScan
1 any any any permit Low
cplogout
1 user controller svc-https dst-nat 8081 Low
guest-web
1 any 192.168.0.0 255.255.0.0 any deny Yes Low
2 any 172.16.0.0 255.240.0.0 any deny Yes Low
3 any 10.0.0.0 255.0.0.0 any deny Yes Low
4 user any svc-http dst-nat ip 163.8.85.68 8080 Low
5 user any svc-https permit Low
6 user any svc-dhcp permit Low
7 user any svc-icmp permit Low
8 user any svc-dns permit Low
9 any any any deny Yes Low
vpnlogon
1 user any svc-ike permit Low
2 user any svc-esp permit Low
3 any any svc-l2tp permit Low
4 any any svc-pptp permit Low
5 any any svc-gre permit Low
Expired Policies (due to time constraints) = 0
(P7FUJI01) #
Highlighted
any any permit low
The first policy is guest-blacklist, which is what all packets hit. (any any permit low). Since the rules are evaluated from top to bottom, they never make it past this rule. Remove guest-blacklist from that ruleset.
Highlighted
Ive just done a test telnet to the proxy ip/port form the wireless client and I can see it works, however, it doesnt appear as if the controller is doing the nat as it should... i cant see how I can find hits based on the guest-web policy
thanks
kris
Highlighted
*slaps forehead* of course!! ok, fixed that. We still cant get through, on the firewall we can see the packet but no web access :( ill check our proxy
Highlighted
Guest Web
Remove all the ACLs besides the guest-web ACL from the user role, because all of the others just get in the way. You can add security back in, when functionality works. I repeat, remove guest-blacklist, cplogout and vpnlogon from that guest role.
Highlighted
Thanks Colin, we've got it working now :) you're a star, thanks!
